References for Two Phase Flow
Old   December 3, 2001, 21:25
Default References for Two Phase Flow
Halim Choi
Can anyone give me references for simulation of two-phase bubbly flow using the two-fluid model and the SIMPLE(SIMPLEC, SIMPLER, PISO etc) algorithm?. Does anyone know the two-phase bubbly flow can be solved by the SIMPLE algorithm when one uses the two-fluid model?
Thank you in advance.
Halim Choi
Old   December 5, 2001, 07:23
Default Re: References for Two Phase Flow
Michael Malin
This reference simulates several cases using the SIMPLEST-based IPSA algorithm for an Eulerian-Eulerian description of two-phase bubble flow in liquids.
Boisson N & Malin MR. Numerical prediction of two-phase flow in bubble columns, International Journal for Numerical Methods in Fluids, Vol. 23, pp 1289-1310, 1996 1996.
There are many other references making use of this algorithm, and a lot of work was done by Lahey and others at Rensselaer Polytechnic, e.g.
Lahey RT The analysis of phase separation and phase distribution phenomena using two-fluid models Nuclear Engineering and Design 122, pp 17-40. Elsevier Publishers BV 1990.
behavior of two phase flow in a pipe Sonia84 FLUENT 5 September 17, 2013 17:31
two phase flow + ice phase and breaking soeren87 OpenFOAM Running, Solving & CFD 0 September 19, 2010 11:20
Two phase flow in a distributor Mohsin FLUENT 5 May 24, 2010 03:57
Validation for laminar Disperse phase flow shashwat Main CFD Forum 0 April 4, 2008 03:20
references on laminar annular two phase flow yfyap Main CFD Forum 0 September 10, 2003 11:15
