November 20, 2001, 09:24 |
Y+ Values
iŽam simulating flow forces on a spool in hydraulic valve with cfdesign (blue ridge numerics)
so i have problems with the validation of my results! cfdesign is using in the k-eps-model wall functions to simulate the turbulent flow next to a wall can somebody explain to me how the Y+ Value works and why ? e.g. -> what happen if the values outside the range given by cfdesign (35 < y+ < 350) -> Y+ values to low: should i unrefine the mesh, which variables are under- or overpredicted -> Y+ values to high: refine the mesh? -> etc. mfg Matthias |
November 21, 2001, 05:24 |
Re: Y+ Values
i suggest you look at schlichting's book 'boundary layer theory'. you get (a)idea about y+ ,(b)the derivation for wall region in terms of y+ and (c) assumptions for wall shear etc., used in the derivation. one shoud go preferably for remeshing (depending on the wall treatment) at the near wall region. some caution, in terms of meshing, should be exersised to address the vicinity of the near wall region, i.e., the wall law region to the fully developed one.
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 07:55 |
max node values exceed max element values in contour plot | jason_t | FLUENT | 0 | August 19, 2009 12:32 |
exact face values | RubenG | Main CFD Forum | 0 | June 22, 2009 12:09 |
strange node values @ solid/fluid interface - help | JB | FLUENT | 2 | November 1, 2008 13:04 |
node values or cell values? | aPpA | FLUENT | 0 | November 10, 2006 09:56 |
