ICEM Cfd+ Periodic boundary conditions
Old   November 16, 2001, 09:32
Default ICEM Cfd+ Periodic boundary conditions
RajaniKumar
Hi, Can any body tell me how to specify periodic boundary conditions in ICEM CFD hexa mesh generation.
Thanks in advance by rajani
Old   November 16, 2001, 10:37
Default Re: ICEM Cfd+ Periodic boundary conditions
Jonas Larsson
Yes, this is a bit tricky.
First make sure that you have defined the periodicity in the Mesh Editor (Geometry/Surface/Mesh Params/Model/Define Periodicity) and save your tetin file.
Then inside Hexa you just need to do Blocking/Periodic Nodes and pick two nodes that are periodic.
You can verify that the periodicity is correct by setting the "Periodicity" display on in the options for the Face display.
Old   November 20, 2001, 07:53
RajaniKumar
Thank you very much for the help. Today i will work on it.
Periodic boundary conditions happy5jump FLUENT 6 May 3, 2017 01:36
periodic boundary conditions fro pressure Salem Main CFD Forum 21 April 10, 2013 01:44
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent ivanddd ANSYS Meshing & Geometry 1 February 3, 2011 01:51
periodic boundary conditions Satish Perivilli FLUENT 0 January 28, 2005 12:54
periodic boundary conditions Ahmed Abdelwahab FLUENT 4 March 9, 2000 17:36
