November 15, 2001, 02:06 |
AutoCad/Iges files/Solidworks
Hi
Does any one have experiance with the generation of iges files from AutoCad that are to be used for geoemtrical input to CFD software. What are the quality of the iges file from AutoCad ? Have anyone experiance with the Solidworks or the combinations of Solidswork and Pro*am ? Thanks very much in advance. Regards Roueds |
November 15, 2001, 11:42 |
Re: AutoCad/Iges files/Solidworks
Roued,
As you probably know, IGES and Step translations are problematic at best for any kind of complex geometry. It's best to work with the native CAD geometry whenever possible. CFdesign reads SolidWorks assemblies in their native Parasolids (.x_t) or Acis (.sat) formats. These formats cover about a dozen other major CAD packages. CFdesign also integrates directly with Pro/Engineer and IDEAS. You can find out more at www.cfdesign.com -Jeff |
November 21, 2001, 05:48 |
We had the same problem with Autocad. A simple way of solving it, is to export your file in .sat format, use whichever commercial package (gambit,...) to read it.Then export it in iges.
Regards |
November 28, 2001, 08:43 |
I have AutoCAD 2000, and it doesn't work with IGES. If you want to use Autodesk's, you might like Mechanical Desktop, which does use IGES files (import/export)
