Axisymmetric Flow
Old   November 10, 2001, 11:15
Default Axisymmetric Flow
S. Kumar
Can anybody help me understanding the finite-volume method for axisymmetric flow? For theory and implementation I am using " Computational Methods for Fluid Dynamics-2nd Edition." by Joel H. Ferziger & M. Peric. and accompanying CAFFA code. I have two points regarding this :
1) On pages 244-246 it explains that general Cartesian code can be adopted for axisymmetric flow if some additional terms are added. Can you please help me understand why it is needed to add the radial component of pressure forces on the front and back surfaces?(page 245) I am also not very clear how this extra term is derived in here. There is a very sort explanation of this fact in here. Is it possible to give some references which treats this in greater details?
2) By studying CAFFA code it appears that gradient vector components at CV-centre for U, V and P all use above mentioned correction terms for axisymmetric flow. Subroutine for calculating gradient is
GRADFI(K,FI,DFX,DFY)
In this subroutine correction for axisymmetric flow is provided and this subroutine is called by another subroutine
CALCUV(K)
This calculates the velocities component.
My question here is -- why is it required to add correction term(1)for all the gradients ?
I will greatly appreciate any help in terms of explanation or reference.
Thank you very much
S. Kumar.
Axisymmetric Flow around a hollow cylinder with an extended flair JLight OpenFOAM 5 January 28, 2013 13:11
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
Test for a laminar flow in axisymmetric nozzle Victor Main CFD Forum 0 November 30, 2005 11:51
Convergence for axisymmetric flow bl201 Main CFD Forum 5 August 16, 2005 18:01
2D axisymmetric flow Andreas Abdon CFX 8 February 25, 2000 09:39
