November 5, 2001, 15:03 |
k-e values
Hi, there,
I am a new beginner working with k-e equations for turbulent flows. I am using low-reynolds version k-e equations with simple eddy viscosity method. I have got a converged solution. But I found that the value of the dispation rate (e) is three order magnitude higher than the value of turbulent kinatic energy (k) generally. Is this reasonable result? I have no idea of this. In general, is there any relationship between these two values? I would be very grateful if any experienced one can tell me this. It is really hard to find such informaiton in the text book. Thank you very much. Best regards |
November 7, 2001, 06:48 |
Re: k-e values
for y+ (y+ = y*u_f/nu) in [30:300], you can make the assumption that :
k = (u_f)^2/sqrt(c_\nu) eps = (u_f)^3/(Kappa*y) so k/eps which has to do whith the characteristic turbulent time scale is propto (Kappa*y)/(sqrt(c_nu)*uf) which could be very small. hope that help, Sylvain PS : Kappa = 0.41 ; c_nu = 0.09 ; nu = 1.5e-5 for air in mks ; u_f is the skin friction velocity. |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 07:55 |
max node values exceed max element values in contour plot | jason_t | FLUENT | 0 | August 19, 2009 12:32 |
exact face values | RubenG | Main CFD Forum | 0 | June 22, 2009 12:09 |
strange node values @ solid/fluid interface - help | JB | FLUENT | 2 | November 1, 2008 13:04 |
node values or cell values? | aPpA | FLUENT | 0 | November 10, 2006 09:56 |
