artifical dissipation on unstructured meshes
Old   October 31, 2001, 18:42
Default artifical dissipation on unstructured meshes
Frederic
Hi all,
I'm trying to implement an artifical dissipation scheme on a 3D tetrahedral mesh. (I want to be able to use central differencing instead of Roe's scheme, which has some implicit dissipation ). Two things: - is there any known example in 3D? Most of the literature I found so far was related to 2D unstructured meshes. - also, most cases precondition the artifical dissipation flux term with a coefficient containing the average eigenvalue at the interface between two neighboring cells (also to keep the dimensions consistant). What is the meaning here of using the local eigenvalues? I think I understood that the goal is to yield more dissipation where the distance between two points is great in the direction normal to the face between those two points (Roe does that all alone). Thanks for anyone's input.
Fred.
Velocity/pressure/Temperature blow-up while dealing with unstructured meshes psosnows OpenFOAM Bugs 4 October 19, 2011 16:48
Merge 2 unstructured meshes vinc ANSYS Meshing & Geometry 0 May 19, 2011 17:14
structured vs unstructured hexahedral meshes Usman FLUENT 0 January 19, 2008 05:20
Structure vs unstructured meshes Des Aubery Main CFD Forum 2 July 26, 2003 00:11
Higher Order FV Schemes for unstructured meshes Apurva Shukla Main CFD Forum 4 December 15, 2000 10:17
