October 19, 2001, 13:54 |
BCS for SIMPLE
In pressure correction equation for the SIMPLE algorithm, BCs when normal velocity or pressure on the boundary are known are easy to implement. Alternatively, at the outlet, one can specify that properties do not vary in streamwise direction. How can one specify in that case the BCs for the pressure correction equation??. Thanks for your comments.
October 19, 2001, 23:26 |
Re: BCS for SIMPLE
Often , for a outlet in incompressible flow, the pressure is imposed. i.e. The variation of pressure is zero.
Dealing with BC's in OF 1.6 | vkrastev | OpenFOAM Running, Solving & CFD | 5 | September 4, 2012 12:58 |
BCs in a Tunnel Modeling | mehdi8619 | FLUENT | 1 | February 16, 2011 18:54 |
p & U outlet bcs for realistic wind inlet profile | stevek | OpenFOAM | 4 | July 19, 2010 03:29 |
BCs for Pressure Correction Equation (SIMPLE) | Bharath Somayaji | Main CFD Forum | 1 | March 1, 2006 07:12 |
Need Assistance: BCs for k-e model implementation | Dean Schrage | Main CFD Forum | 3 | August 11, 2001 02:02 |
