stability of converging flow
Old   October 16, 2001, 08:59
Default stability of converging flow
Bo Busk Jensen
Hallo All
I am trying to model a converging flow between two parallel discs. The flow concides in the centre and leaves through a hole in one of the discs. My question is: Hoow is the stability of this flow?? Will it be axis symmetrical around the centre axis og the discs or will it start rotating???
Regards
Bo
Old   October 16, 2001, 15:58
Default Re: stability of converging flow
John C. Chien
(1). In theory, if the inflow is radial, then the outflow should not have the tangential component, because of angular momentum conservation. Flow acceleration is normally stable in this case. (2). In real test, you have influence of the earth gravitational and rotational field. So, it is hard to eliminate the inflow rotation. (3). Also, the small perturbation in inflow condition can be magnified easily at the center with raducing radius. Thus, it likely to have swirl component. (4). If the inflow is radial, then axisymmetric formulation could be used. In that case, it will be symmetric all the time. Even in 3-D, I think, it is still possible, if your method is good. If the formulation is in Cartesian, while the geometry is symmetric, then I think, there is no guarantee that the flow will be symmetric with no swirl.(numerical errors)
Old   October 17, 2001, 03:38
Bo Busk Jensen
Thanks John
Is it possible that you could give me a reference containing information about this?? I need for a paper I am writing.
Regards
Bo
Flow is not converging in natural convection problem of boussinesq model for air rahulsharma FLUENT 4 December 2, 2020 22:07
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 14:00
Mass flow and U-Mom flow in CFX Zhihua Xie CFX 0 September 3, 2007 10:49
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
the stability of compressilbe flow using LES model ricklee Main CFD Forum 0 August 27, 2005 15:33
