moving cylinder
Old   October 11, 2001, 03:33
Default moving cylinder
blur boy
Hi! I'm doing this code on an external body flow. Basically I need to use the standard 2D Cartesian coordinates (x,y) to compute the flowfield around a moving circular cylinder WITHOUT moving the cartesian grid. The frame is fixed and the cylinder is moving in a fixed prescribed velocity and I'm using the streamfunction-vorticity formulation of the Navier Stokes equation to compute.
Usually if the cylinder is fixed (not moving), we can derive the streamfunction at the cylinder by using the summation of (del operator x vorticity) along the cylinder surface. But for moving cylinder, that is not the case. Does anyone know what equation should I use to derive the cylinder streamfunction for the moving case?
Thank you!
Old   October 11, 2001, 15:41
Default Re: moving cylinder
Adrin Gharakhani
fix your frame of reference on the cylinder
Adrin Gharakhani
Old   October 11, 2001, 19:40
Jongdae Kim
Old   October 11, 2001, 19:41
Jongdae Kim
What about immersed boundary method?
Old   October 12, 2001, 06:32
blur boy
I'm trying not to fix my frame to the cylinder, in case for my future developments, I will need to oscillate two or more cylinders within the same field.
So basically I'd have a "sub" frame moving with the cylinder but with reference to a stationary cartesian frame.
Flow over a Cylinder. 2D vs 3D cylinder (moving) ojha.mayank485 CFX 0 June 20, 2011 16:25
Moving a Cylinder in cross flow after solving Dynamics equations of motion maruthamuthu_venkatraman OpenFOAM 1 November 19, 2009 14:55
moving cylinder in a cartesian grid yusun Main CFD Forum 1 July 1, 2009 04:48
Confined or moving cylinder Mohamed GUEROUACHE Main CFD Forum 1 October 23, 1999 16:20
Confined or moving cylinder Mohamed GUEROUACHE Main CFD Forum 0 October 19, 1999 12:00
