Fluid in a rotating cylinder
Old   December 17, 1998, 17:26
Default Fluid in a rotating cylinder
Fluid Novice
I have a closed cylinder that has 10% of its volume filled with water. The cylinder can rotate at low and high speeds and I'd like to know how I can go about describing the behaviour of the fluid in the rotating cylinder at those speeds. Any suggestions on boundary conditions and information on velocity distributions would be greatly appreciated.
Old   December 17, 1998, 18:25
Default Re: Fluid in a rotating cylinder
John C. Chien
I think a similar question was asked here sometimes ago. It has very simple analytical solution and was given in a text book. If you search through this forum, you should be able to find the exact answer.
Rotating cylinder raul FLUENT 3 February 1, 2015 06:48
Strange pressure distribution with a rotating cylinder HiF OpenFOAM Running, Solving & CFD 0 July 17, 2010 01:06
rotating cylinder using sliding mesh Tim Daly FLUENT 1 November 10, 2008 00:02
Rotating cylinder Johnny Main CFD Forum 5 December 7, 2004 10:55
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
