higher gauss Quadrature rule for triangles
Old   September 27, 2001, 14:33
Default higher gauss Quadrature rule for triangles
R.A.Khurram
Dear friends I am doing certain error analysis in FEA. In order to eliminate the Numerical Integration error, I want to use higher gauss quadrature rule for triangles. I have found 10x10 rule for Quads but i could not find it for triangles. Presently I am using 12 point integration for triangles. if any body have used it or know some literature, then i will need his help
I appreciate your help
Old   September 27, 2001, 14:39
Default Re: higher gauss Quadrature rule for triangles
COBOK
The easiest way is to consider a triangle as a degenerated quadrangle (when two of the vertices collapse into one). Note that higher-order quadratures are readily available for quads.
Problem in fvschemes divSchemes cannot use Gauss linearUpwind nico765 OpenFOAM Bugs 30 August 9, 2018 08:39
please help me which solver is better for my application Ger_US OpenFOAM 8 January 8, 2013 13:29
Gauss Quadrature points dhruv OpenFOAM 4 September 26, 2011 05:59
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 02:23
Quadrature Rule for Triangles Khurram Main CFD Forum 3 August 28, 2002 20:15
