Control Volume Gradient
Old   September 25, 2001, 09:40
Default Control Volume Gradient
Barry
Dear all
Can anyone tell me / give references of alternative methods to Gauss/Green to compute gradients of for example a scalar over a control volume.
Gauss (grad Phi)~1/V Sigma_faces (Phi_face x areavector_face)
Old   September 25, 2001, 10:04
Default Re: Control Volume Gradient
Jim Park
I'll not try to dig out multiple references.
My point (helpful or not) is that there are a great many ways to calculate Phi_face.
What you choose depends on your experience, your problem, your overall algorithm, economics, the physics you're trying to simulate.
Not the answer to the question you asked.
Old   September 25, 2001, 10:12
Barry
Dear Jim
Say I have phi_face. I'm just looking for alternatives to Gauss for the gradient calculation.
Regards
Old   September 25, 2001, 11:36
Kang, Seok Koo
The least squares method can be an alternative to the green-gauss theorem for calculating a gradient of a scalar over irregular control volumes. Both are useful and cannot say which is better; because it depends on the situation.
In my experience, two methods show similar results. The method of least squares is sometimes used in special scheme such as least-squares ENO, but it can take the place of green-gauss.
Old   September 26, 2001, 02:37
Barry
Dear Kang
Could you maybe provide references of where the least squares method is explained? Thank you
Old   September 26, 2001, 07:08
Kang, Seok Koo
One example of calculating a gradient of a dependent variables over a control volume is presented here. Hope this will help you.
N. BALAKRISHNAN AND G. FERNANDEZ, WALL BOUNDARY CONDITIONS FOR INVISCID COMPRESSIBLE FLOWS ON UNSTRUCTURED MESHES, Int. J. Numer. Meth. Fluids 28: 1481-1501 (1998)
Old   September 26, 2001, 16:54
Phil Zwart
Tim Barth, "Recent Developments in High Order K-Exact Reconstruction on Unstructured Meshes", AIAA Paper 93-0668, 1993.
This paper describes a least-squares procedure for calculating gradients and Hessians. Gradients only are a simplification of this procedure.
Old   September 27, 2001, 08:15
Barry
Thank you for the references
Old   September 27, 2001, 13:28
Praveen
Least squares reconstruction is also used by Carl F. Ollivier-Gooch. See his papers on his website. You can download some of them.
http://tetra.mech.ubc.ca/~cfog/publications/index.html
Gradient of Volume fraction in UDF Babar Sharfuddin FLUENT 2 February 29, 2020 05:29
gradient calculation of cell centered finite volume method zhengjg Main CFD Forum 10 November 12, 2012 00:13
Control of volume fraction rakadit Main CFD Forum 3 August 19, 2011 06:15
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
how to calculate the gradient of volume fraction hxhua FLUENT 0 July 1, 2005 09:43
