Engine Design: is there a good CFD book?
Old   August 31, 2001, 12:36
Default Engine Design: is there a good CFD book?
Geoff Rathbun
I'm developing some simple existing code for a Stirling Engine. I have no CFD theory books and am just working from basic fluid mechanics equations. It seems to be working OK, as I get meaningfull results... but oscillations are common. I figure I need to look at relevant theory to help me on my way. I am modelling a Stirling Engine in 1D only (this is adequate I feel). Model must handle wall friction and compressibility as well as good heat transfer effects.
Is there a good book out there that applies well to my field of interest?
thanks for your interest....
Old   August 31, 2001, 13:26
Default Re: Engine Design: is there a good CFD book?
John C. Chien
(1). Depending upon the final modelled equation, you can select the proper method to solve it. (2). "Applied Numerical Methods" published in 60's, will have Fortran codes for various types of problems. It will be either parabolic or hyperbolic (or even mixed). Why not take a look at the numerical analysis book first.
Old   August 31, 2001, 20:48
Gordan Feric
Geoff:
If you need help with physical properties and other numerical values, check out the Engineering Software (EngWare) web site at: http://members.aol.com/engware where you can find lots of free material such as: slide shows, online calculators, demos etc.
Gordan
Free CFD book, help with the CFD Events Calendar Jonas Larsson Main CFD Forum 0 May 9, 2003 13:07
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 22:10
part-time-cfd Michael Main CFD Forum 6 February 2, 2000 13:01
CFD - Trends and Perspectives Jonas Larsson Main CFD Forum 16 August 7, 1998 17:27
salary range Frank Muldoon Main CFD Forum 7 August 3, 1998 20:04
