Micro pump design / Diaphragm pump
Old   August 29, 2001, 08:52
Default Micro pump design / Diaphragm pump
Michael
I am designing a diaphragm type micro pump (50x20x20 mm). I am having a hard time trying to forecast the performance of the pump before prototyping. Has any one done any sort of work in this area before? The pump operates at relatively high speeds (7000rpm). I have a few items that I need to solve before prototyping. They are dynamic balancing, valve design optimisation and performance calculation. There are no standard formulas or packages that can solve these problems for me. Can any one help?
Old   August 29, 2001, 10:44
Default Re: Micro pump design / Diaphragm pump
Alton J. Reich
Michael,
We have done quite a bit of work on micropumps of various types. I would encourage you to look at our web site <www.cfdrc.com>, especially in the biomedical area to see some of the designs we've worked with in the past.
We can either team with you to look at and improve your pump design, or supply you with the tools you would need to do it yourself.
If you have any additional questions, please feel free to contact me via e-mail or by phone (256)726-4919
Regards, Alton
Old   March 1, 2013, 02:56
dataha gabata
hayabura is on a distinguished road
thank you very much
diaphragm pump
vacuum pump
hayabura is offline   Reply With Quote
micro channel heat exchanger design serpil kaya Main CFD Forum 6 March 25, 2018 08:34
NUMECA-Optimization of pump design using FINE/Design3D mahdi balali Fidelity CFD 9 May 1, 2012 12:02
CFD Package for Water Pump Design !!! John Sheng Main CFD Forum 7 September 4, 2001 10:29
CFD pump design. Jack Keays Main CFD Forum 15 March 30, 2000 19:05
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
