variations on the equation of continuity
Old   August 10, 2001, 08:22
Default variations on the equation of continuity
98.4F
Hi
How is the equation of continuity for a layer written. There some different way of writing it using radial volume fluxes and thickness of the layer but how is it done and how do they get an equation like this
d h/dt = d(psi_1)/rdr + d(psi_0)/rdr - (Q2 - Q1)
where d is the partial derivative h is the thickness and psi are the radial volume fluxes per unit radian which are defined by
psi = -h*u*r where u is the radial component of velocity.
Thanks
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
mixture mass continuity v.s. volumetric mixture continuity in pressure equation kaifu OpenFOAM 0 June 9, 2011 09:14
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
