Quadratic Upwind Interpolation
Old   July 25, 2001, 17:00
Default Quadratic Upwind Interpolation
Frederic Felten
Hi there,
I am seeking references giving the expression for the coefficients used in the QUICK interpolation scheme for non-orthogonal and non-uniform grids.
Thanks in advance,
Frederic Felten.
Old   August 1, 2001, 11:09
Default Re: Quadratic Upwind Interpolation
Romuald
Hi Frederic,
try the following article:
Darwish et al.; Numerical Heat Transfer B; Vol. 26; 1994; pp79-96;
Good luck and best regards
Romuald
Old   August 1, 2001, 12:41
Frederic Felten
thanks for the answer, but i actually derived the quadratic interpolation on paper, and it is very easy to figured out the coefficients. I posted the message without trying to do it myself first. I guess i was just lazy.
Thanks anyway, Sincerely,
Frederic Felten,
Old   August 1, 2001, 15:15
kalyan
Frederic,
From you posting here, I got the impression that you are involved in code development for LES and your group is pretty gung-ho about minimizing artificial damping. Why this sudden interest in QUICK which usually leads to some damping. JUst curious.
Old   August 1, 2001, 21:00
Frederic Felten
Well, that's a good question. Actually we are trying to understand why some people have used the QUICK scheme in collocated curvilinear geometry when others have just used a second order central difference scheme (CDS).
We realized that when the geometry is simple, like a wavy channel, the second order CDS works fine ,and almost no oscillations are present in the field. ( check Armenio and Piomelli,
Flow, Turbulence and Combustion,
vol 65, pp 51-81, 2000 )
When the geometry becomes a bit more complex, like a polar cavity, or flow in a bended duct (Check Zang et al. , J.Comp. Phys., vol 114, pp 18-33, 1994) a dissipative scheme like QUICK or SHARP is used to smooth out the field and not get just junk from the oscillations.
Actually i'm currently finishing the redaction of a paper that will be presented a the 3rd AFOSRThird AFOSR International Conference on Direct Numerical Simulation and Large Eddy Simulation (http://math.uta.edu/~taicdl/) next week. The paper addresses some of these issues and some better ways of getting ride of the oscillations without using QUICK. If you are interested, i'll send you a copy of this article as soon as the conference is over.
Sincerely,
Frederic Felten.
2nd order upwind vs 2nd order upwind!!! Far Main CFD Forum 7 March 14, 2013 13:29
Use of upwind scheme for interpolation of u/v quarkz Main CFD Forum 6 August 30, 2011 05:10
Second order upwind is not UPwind!!! Far CFX 9 May 31, 2011 09:21
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 02:23
Interpolation scheme for characteristic upwind for compressible flow enok OpenFOAM Running, Solving & CFD 0 May 8, 2006 15:37
