Trailing edge
Old   July 17, 2001, 05:27
Default Trailing edge
Tom Kent
has someone experience with the difference wheter the leading edge of an airfoil is tapered or bluff ? What's the influence regarding lift and drag ?
Best regards
Tom
Old   July 17, 2001, 15:13
Default Re: Trailing edge
John C. Chien
(1). It is hard to answer your question because the trailing edge geometry is a function of the application and design. (2). If the application is such that the trailing edge can be made very thin and smooth, then the drag can be minimized because the wake region will be thinner. (3). If the the structure reason or cooling purpose, you need a thick trailing edge, then the drag created by the wake region will be higher. (4). So, it depends on the design purpose of the airfoil and its application.
Y-Plus values at aerofoil leading edge and trailing edge at high incidence Engr07 Main CFD Forum 4 June 29, 2012 11:42
[ICEM] Hole near sharp trailing edge of airplane/wing geometry jlichtwa ANSYS Meshing & Geometry 2 September 21, 2010 16:19
Which trailing edge is correct for meshing of aerofoils for CFX LSC CFX 0 May 10, 2009 13:45
