CFD Problem: volumetric compressor
Old   June 28, 2001, 05:17
Default CFD Problem: volumetric compressor
Gabriele Velenich
Dear Sirs, I would like to ask you a technical question about a CFD problem. I have a volumetric compressor with this features: - two rotating blades who defines a variable volume mesh - leackage between blade and housing
Do you know if it is possible to solve this problem (2D problem) with any software? I know that the small number of volumetric compressor published in the literature is mainly due to the complexity of this problem: - the magnitude of compressor dimensions varies from several centimetres for the compression chamber to few micrometers for the clearances - variable volume mesh
Can you send me any information?
Yours sincerely
Gabriele Vèlenich
Old   June 30, 2001, 09:34
Default Re: CFD Problem: volumetric compressor
alain
Dear gabriele
As a matter of fact volumetrics compressor are actually hard to model.
Some cfd commercial packages have the theorical capactity to model some kind of compressor. I know tree of them which may do the job and you will find more information on the editors web site :
CFD ACE form CFDRC STAR CD from computational dynamics FLUENT V4 from fluent inc.
Tip clearance arise others problems (high cell ratio at first) and, in my point of view, should be studied a part form the whole compressor.
I hope this could help you a little
Best regards
Alain
Old   July 2, 2001, 09:15
Rajani Kumar
tryout CFX Taskflow. It has some special features for this problems. by rajani
VAWT transient cfd problem ArslanOZCAN FLUENT 3 January 26, 2011 07:25
CFD analysis of Centrifugal compressor murthy pnvr CFX 3 November 12, 2010 12:13
ill-posed CFD problem ? Noel Main CFD Forum 9 March 28, 2007 12:37
What is the Better Way to Do CFD? John C. Chien Main CFD Forum 54 April 23, 2001 09:10
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 22:10
