Compressible NS code with SIMPLE
Old   June 25, 2001, 13:47
Default Compressible NS code with SIMPLE
S. Kashan
I am looking for a source code (FV) that implemets SIMPLE for compressible flows. would you kindely refere me to such code. Regards
Old   June 25, 2001, 15:12
Default Re: Compressible NS code with SIMPLE
John C. Chien
(1). Please take a look at the forum/resources section first. (2). And post your CFD specific questions here. (3). It is your responsibility to do Internet search.
Old   June 26, 2001, 19:23
ab
do you mean website/resources John ?
Old   June 27, 2001, 00:17
ab
I'm currently acting in order to free-up a code of the refered type, but I would like to be informed about your goals before giving any further information, and any result shouldn't be expected before a few monthes...
Would you like to find some open source code to base an ASP application ?
Anyway, I'm feeling tired of all those guys asking about free codes and never releasing their contributions. If you want some repository, one shall be able to find some for you. Better would be having some CVS available around 'webcfd.com' website. Thank you for advertising your free codes,
Old   July 2, 2001, 06:08
Saud Khashan
HELO AB
Thanks for the reply, I WILL BE VERY INTERESTED IN YOUR CODE. I AM PLANING TO LOOK OUT THE PRESSURE-DENSITY-VELOCITY (POSSIBLY TEMPERATURE) COUPLING ON LINE OF SIMPLE METHOD AS DESCRIBED BY LILIK, DEMEDRIZIC AND PERIC. PAPER. (??? ). As far as i know, such method is highly dependent on tuning parameters (mainly under-relaxation almost every where!!). So i will use the code to "resrach" this issue.
regarding "Webcfd.com" it is not in use. any idea how to inxest on it!!!?
SIMPLE pressure correction in compressible flows Maarten de Jong Main CFD Forum 7 April 30, 2012 03:23
sample MAPLE code for SIMPLE algorithm mia Main CFD Forum 0 February 28, 2009 00:22
A simple CFD code for teaching basic CFD? Christoph Lund Main CFD Forum 13 September 14, 2005 05:36
On SIMPLE algorithm in compressible flow situation Abhijeet Vaidya Main CFD Forum 3 October 18, 2001 06:46
Compressible Viscous Code vaidation test cases? Mohammad Kermani Main CFD Forum 2 November 11, 1999 15:22
