June 15, 2001, 19:01 |
Plotting Iso Vorticity Surfaces
Hi there,
I am trying to plot Iso Vorticity Surfaces, for overset grids, using the grid files and the Q files for 2 bladed rotor. Which is better to be used, FAST or FIELDVIEW. or somebody know a better sorfware. Any help will be appreciated ! Thankyou, -Radhika |
June 17, 2001, 02:03 |
Re: Plotting Iso Vorticity Surfaces
(1). FIELDVIEW is a commercial product, so, I think, you can contact the vendor and get the needed information and support. (2). FAST is from NASA, so I don't know whether you can get your needed support of not.
June 21, 2001, 05:00 |
We use fieldview and make a lot of vorticity plots. Fieldview works great with vorticity (iso-surfaces, whatever you want) Don't know about FAST
June 21, 2001, 05:29 |
Dear John
I admire the way you have to write two sentences and to say nothing. Regards Kike |
June 21, 2001, 13:42 |
(1). The fact is I have used both software. (2). If you are good, you can use FAST. (3). If you need help, then try the commercial one.
June 22, 2001, 18:26 |
Hi Brat and others,
If you have worked in Fieldview can you please tell me how do I plot, Iso vorticity surfaces. Whenever I tried plotting I get some, box type very weired looking surfaces. Thanks, -Radhika |
June 25, 2001, 03:22 |
After you created the variable vorticity and you select it as the iso-function, it should be ok. You can have fieldview calculate the velocity gradients needed for the velocity or your own program. I don't know anything about your solution so I don't know what's wrong. We've had no problems yet with Fieldview.
Regards, |
Text Commands For Iso Surfaces | Justin | FLUENT | 1 | January 8, 2009 05:49 |
Plotting Vorticity in CFX 11 | Venkatesh | CFX | 4 | August 6, 2008 07:26 |
Vorticity iso surface around propeller in CCM+ | Dan | Siemens | 2 | January 23, 2007 15:17 |
Problems with iso surfaces. | Chris | FLUENT | 0 | June 2, 2005 11:22 |
iso surfaces in parallel | Frank Muldoon | Main CFD Forum | 2 | July 11, 2002 14:17 |
