June 1, 2001, 05:22 |
about pseudo time
Dear sir,
I have read 'A Time-Accurate Algorithm for Chemical Non-Equiplibrium Vicous Flows at All Speeds" of 'J. S. Shuen et. al. and I have some problems but I cannot contact the authors. Could you give me some suggestions for the following questions please? -------------------------------------------------------------------- 1. After doing some mathematical manipulations, we obtain the Navier-Stokes equations in a conservation form in curvilinear coordinates: (P)[d(Q_hat)/d(tou)] + [d(Q_star)/d(t)] + [d(E_star)/d(sine)] + [d(F_star)/d(eta)] = H where Q_hat is J*[ p_g u v h]_transpose tou is the pseudo time t is the physical time H is the source term The author say that "the eigenvalues (in the sine-direction) in the pseudo-time can be obtained from the matrix [(P_transpose)*A], where A is the jacobian [d(E_star)/d(Q_hat)]." My problem is what do I do with the eigenvalues obtained? Actually I don't know why we have to find them. Use them to find the delta_tou? How? and do I have to consider the eigenvalues in eta-direction? What is the different influent on the pseudo-time term of these two set of eigenvalues? ----------------------------------------------------------------------- 2.After discretization, the dual time-stepping integration method is chosen. (Actually I still have the problem how to apply this method to this equation, the author don't say in deep detail.) The author say that "the physical time step size, delta_t, is determined based on the characteristic evolution of the unsteady flow under consideration, the pseudo-time step size, delta_tou, is determined based on the numerical stability of the algorithm and can be adjusted to give the optimum convergence rate for the pseudo-time iteration procedure." My problem is I do not understand how to find delta_t and delta_tou, and how to adjust it? Could you give me some explaination or some examples please? ---------------------------------------------------------------------- 3. The author said that he used a modified strongly implicit procedure. Could you give me some explaination about this procedure please or give me some examples of how to apply them please? --------------------------------------------------------------------- Thank you very much sir. Best regards, Atit Koonsrisuk |
June 1, 2001, 13:51 |
Re: about pseudo time
The strong implicit procedure (SIP) is also called the Stone method in applied math. circles. It is basically a kind of incomplete cholesky algorithm. You can find it explained in the book by Ferziger and Peric.
Time step size and max iterations per time step | pUl| | FLUENT | 31 | October 23, 2020 23:50 |
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 10:08 |
pseudo Time stepping vs real time stepping | nileshjrane | Main CFD Forum | 0 | October 19, 2010 06:13 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
