cfd calculations on fish
Old   May 29, 2001, 18:18
Default cfd calculations on fish
Martin Nilsson
I am currently working on a little project regarding cfd calculations on fish. I have only just begun and i would therefor like to ask for any information on the subject. I am planning to write a new or modify an existing code. I would therefore be interested in codes that I could start from. The code will be incompressible, transient, inviscid at first (viscosity later), moving grid, and preferably written in fortran. nay help, suggestions, hints on the matter are appreciated.
Old   May 30, 2001, 02:11
Default Re: cfd calculations on fish
John C. Chien
(1). What kind of fish? (2). How do you model the fish geometry, especially when the fish is moving?
Old   May 30, 2001, 10:16
Martin Nilsson
What kind of fish? Any somewhat common fish will do, bass, cod, herring etc They all more or less have the same topology. Modelling the fish should not be so difficult. one grid with maximun deflection in one, say x direction, and then a second one with maximum deflection in the -x direction. Then I will interpolate between the two to account for the fish moving it's tail. Possibly I need to use some grids in between as well.
Martin
Old   May 30, 2001, 13:20
John C. Chien
(1). Well, that's a mechanical fish. (2). I have noticed that the fish open and close the mouth at roughly one second a time, to get needed the water and oxygen. (2). Why not just use three rectangular plates to simulate the fish motion. In that way, you can simplify the modeling work. With two hinges, you can position the plates at any angles to simulate its motion. (it's not going to have the mouth anyway.)
Old   May 30, 2001, 18:10
Martin Nilsson
Simplifications are always made, no? And it is the propelling motion I am interested in, and I am quite sure that the flow through the fish is not all to involed in that. Besides, I want to have the possibility to use different deflections on the fish's tail.
Martin
Old   May 30, 2001, 18:21
John C. Chien
(1). In that case, 3D Studio Max is probably a good software to model the fish and animation. (2). I have used the software since early 90's, and I think it can model quite complex geometry.
Old   May 30, 2001, 19:08
Adrin Gharakhani
Check
H. Liu & K. Kawachi, "A Numerical Study of Undulatory Swimming," J. Comp. Phys., Vol. 155, pp 223-247, 1999.
Adrin Gharakhani
Old   May 30, 2001, 19:31
bronze
Here is an article in Annual reviews in Fluid Mechanics 32(1)33. (2000)
Hydrodynamics of Fishlike Swimming
================================================== ==== http://fluid.annualreviews.org/cgi/c...eabstract=fish+motion&searchid=QID_NOT_SET&stored_search=&FIRSTI NDEX=&journalcode=fluid
================================================== ==== these may or may not be of interest...
http://web.mit.edu/afs/athena.mit.ed...ects/fish.html
http://www.cee.hw.ac.uk/~sfakios/html/swim.htm
http://www.csuchico.edu/~pmaslin/ichthy/loco2.html
Old   May 30, 2001, 20:58
John C. Chien
(1). Thank you for the websites information on fish motion.
Old   May 31, 2001, 17:49
Rick Harris
Hello;
Meldon Wolfgang's PhD thesis (mentioned in the Annual Review article) presents 3-d unsteady results for a swimming fish. I believe he modified PMARC to do the calculations. I've also been modifying PMARC for modeling flow about morphing bodies and it seems to work pretty well for my stuff.
Regards,
R
Old   June 1, 2001, 15:34
  #11
clifford bradford
Bass, cod, herring?! You should model a high performance fish! I suggest a tuna as the geometry is relatively simple. Some guys at MIT have done research on a robotic tuna that you may want to find out about.
Old   June 1, 2001, 16:30
  #12
Martin Nilsson
High performace fish? Well, they all use the same principles, and once I can model one, I can do all. I have looked at the stuff MIT have done and I must say I like it. Does anyone know what code they used? But to begin I will probably invent a fish. If anyone have a meshed fish (structured hex) I would be most grateful.
Martin
Old   June 1, 2001, 18:07
  #13
Adrin Gharakhani
If I remember correctly, the MIT people (like most others) used an inviscid model and the vortex-panel approach. Actually, if you do a simple literature search you'll see most analyses, beginning by Lighthill all the way until very recently, use a thin (curved) plate model and "shed" vorticity at the tail. For this work, the original/inviscid vortex panel method probably works best if the interest is the long wake behind the fish (or a school of fish). In many respects, to first order, flow over a fish is similar to flow over a wing in the sense that there is little/no massive separation. Fish is smarter, though, as it can use the shed vorticity to propel forward.
Adrin Gharakhani
Old   June 1, 2001, 20:06
  #14
clifford bradford
Martin, lighten up man I was joking! The MIT work to which I was refering was some experimental work that was done with a robotic tuna in a water tank. If I remember correctly the robot was called Charlie.
Old   June 4, 2001, 14:31
  #15
Martin Nilsson
Irony is hard to catch over the computer.
Martin
Old   June 16, 2001, 06:25
  #16
clifford bradford
Hence the smiley face or should I use the wry face :-?
Heh heh
Min. Hardware for CFD calculations mra Hardware 3 April 12, 2010 04:47
ASME CFD Symposium - Call for Papers Chris Kleijn Main CFD Forum 0 September 25, 2001 11:17
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 August 21, 2000 05:49
PC vs. Workstation Tim Franke Main CFD Forum 5 September 29, 1999 16:01
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 13, 1999 00:27
