turbine database
Old   May 21, 2001, 13:35
Default turbine database
francesco montomoli
I'm looking for some experimental data about steam or gas turbines to validate a code for turbomachinery applications. Can someone help me?
Old   May 21, 2001, 13:57
Default Re: turbine database
John C. Chien
(1). The best place to start is ASME/Journal of Turbomachinery. From there, you should be able to find additional information from references of the paper.(2). There are also websites about cfd test cases, but I am not familiar with those sites. You can do some search in the Resources section of this forum.
Old   June 7, 2001, 17:52
Thomas P. Sommer
Most of the available data is proprietory, so either the results or the geometry are not published. In Europe, you may be able to get access to the ERCOFTAC test cases http://www.mecaflu.ec-lyon.fr/CONGRES/ERCOFTAC/
Problem with torque output from a turbine simulation. pa-dundas FLUENT 5 July 17, 2022 06:27
FSI - Wind Turbine AUN CFX 13 August 29, 2012 17:44
Where can I get geometry (database) for wind turbine blades and towers CFDuser2009 Main CFD Forum 2 August 2, 2009 00:10
turbine noise naser FLUENT 0 December 3, 2004 14:37
Can't open the database. Help Please! CFX Begineer CFX 1 October 27, 2002 14:08
