Tridiagonal System
Old   May 21, 2001, 04:47
Default Tridiagonal System
Zhong Lei
Hi, I wanna if there is any method to efficiently solve a 1-d tridiagonal linear system quation on a vector machine. Any idea?
Thanks in advance.
Old   May 22, 2001, 22:04
Default Re: Tridiagonal System
Ray-zoo
Solution from tridiagonal linear equations could be computed with Thoma's algorithm, wich is "pivot de Gauss" method for this particular case.
Do you really need a vector machine for this ?
Please, ask for the algorithm.
Best regards,
Christophe
Old   May 23, 2001, 00:04
Zhong Lei
The vector rate of Thoma's algorithm is too low when it runs on a parallel machine. I want to improve the vectorization. of the following do-loop.
<DD> do I=1,IMAX <DD> D(I) = D(I) -W(I)*D(I-1) <DD> enddo </DD>
Thanks Zhong Lei
Old   May 24, 2001, 15:18
Ray-zoo
Dear Zhong Lei,
Apologises for this late answer due to sparse internet connection.
After a read of J.C. Chien's post about vector machines, I could not guess how to vectorize a loop which requires previous iteration step result.
As I am mostly newbie to this forum, I can not confirm own opinion that meaningless requests may be a reason for none, or very few answers.
If you need running some parallel machines, couldn't you run some domain decomposition method (ddm) ?
I had an internet link to those methods, but could not find it before this post.
Maybe someone else here knows where to find informations about ddm(s).
Yours,
Christophe
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
code for solving block tridiagonal system cfd Main CFD Forum 22 December 24, 2010 18:15
block tridiagonal system solver for periodic bc Abdullah Main CFD Forum 8 February 23, 2007 14:15
On the block tridiagonal linear system zhanglei Main CFD Forum 2 July 24, 2000 07:15
On the block tridiagonal linear system zhanglei Main CFD Forum 0 July 18, 2000 09:55
