Impinging Jet Boundary Conditions
Like Tree2Likes
Old   January 8, 2012, 01:11
Cool
  #21
MK
takin is on a distinguished road
Originally Posted by elisun View Post
Hi.
I've got a problem with modeling an impinging jet with fluent. do i have to model the nozzle too? i mean since the flow has to be fully developed in the outlet of the nozzle, do i need to create the geometry of a pipe in gambit , or it's enough to just consider the exit of nozzle?
Tnx alot.
it depends on tha H/D ratio. if the distance betveen nozzle exit and impinging wall is small, the velocity profile at the nozzle outlet may affect on the ressults, specially at the stagnation point. but i think you should set a fully developed profile at the nozzle exit with UDF. for laminar flow, you can use a parabolic distribution like this:
u(r)=u_max (1-(r/R)^2),
where
u_max=1.5*u_avg, for 2D cartesian
u_max=2*u_avg, for axisymmetric problem
for turbulent flow, you can use 1/7 law but I think the velocity distribution does not affect the results severly.
takin is offline   Reply With Quote
Old   January 8, 2012, 01:16
Smile
  #22
MK
dear Anindya!
you should consider to your computatinal domain. the width of domain (from symmetric plane to outlet) must be large enough to use pressure or outflow condition (say 10 to 15 times more than D). also, you should note that what kind of impinging geometry you have (i.e., confined or unconfined).
Old   January 10, 2012, 16:45
Exclamation
  #23
anush
flashkicker9 is on a distinguished road
hi, everybody i am new to the gambit and fluent software, and i needed help solving a converging nozzle problem,i am not getting the convergence in iterations, its actually showing lot of divergence during iteration process,
and it ends with warning like reverse flow at outlet and turbulent flow at outlet.
i have selected viscous flow to be -spalart allamaras and the courant number as 5. i have used solver as density based and fluid as Air(property-ideal gas).
As the iteration progresses the reverse flow and turbulent flow error is shown, after 80-90 iterations it shows divergence and accordingly it reduces the courant number from .5 to 5e-5 for each iterations and it ends with floatation error.
below is image of my model- the white region is wall, the pink region is pressure far field, and grey(ish) region is pressure inlet.
i need to find the flow characteristics of compressible flow in nozzle.
plz plz plz reply asap...
thank you for your time
flashkicker9 is offline   Reply With Quote
Old   January 11, 2012, 00:22
MK
Dear Flashkicker9!
I think the problem is caused by your pressure far field boundary. there is a limitation to use this kind of condition, that the far-filed boundary should not have broken edge (like a cube) you must use a curved surface instead of broken one. use a half-sphere instead of this cube.
Old   January 11, 2012, 14:40
Exclamation
  #25
anush
Originally Posted by takin View Post
Dear Flashkicker9!
thank you it helped me solve for 2d and i am gonna try for 3d, but what condition to take for the compressible flow?
Old   February 27, 2016, 13:58
Default Modelling 2D jet impingement on a flat plate
  #26
Mark
MarkTwain is on a distinguished road
Hi All,
I am tasked with modelling a 2d axisymmetric jet impingement on a flat plate but I have no clue how to begin modelling this.
Can anyone help with this?
Thanks
Mark
MarkTwain is offline   Reply With Quote
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Boundary conditions in FireFOAM 1.7.1 for Jet Fires hafiidz OpenFOAM 2 December 8, 2010 11:09
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 02:54
Boundary Conditions Jan Ramboer Main CFD Forum 11 August 16, 1999 09:59
