How to determine the time averaging factor?
Old   April 15, 2001, 22:45
Default How to determine the time averaging factor?
Hai-Wen Ge
In time averaging technique,how to determine the time averaging factor?Is there any reference explaining it detailedly? Thanks!
Old   April 18, 2001, 10:35
Default Re: How to determine the time averaging factor?
Chidu
Hi Hai-Wen,
Can you elaborate on your question a little bit more? The meaning is totally unclear.
chidu...
Old   April 18, 2001, 22:19
Hai-Wen Ge
Now I work on a hybrid Finte-Volume/Monte-Carlo method for joint PDF equations.Some quantities used in FV scheme is extracted from particle field(e.g.,Reynolds stress).To reduce the statistical error,a time averaging technique is employed. Assuming the quantity in FV scheme is Q_{fv}, in MC scheme is Q_{mc}. Q_{fv}^{n+1}=(1-factor)*Q_{fv}^n+factor*Q_{mc} where "factor" is the time averaging factor. The question is:how to determine the value of "factor"? is it problem depend?If yes, what does it depend on?If the value is specialized by experiment, could you suggest a value?
Thanks!
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 07:55
time and ensemble averaging. Mohsin FLUENT 0 May 19, 2011 04:24
export time steps for ensemble averaging Thomas Baumann Siemens 0 March 2, 2010 04:19
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
unsteady calcs in FLUENT Sanjay Padhiar Main CFD Forum 1 March 31, 1999 13:32
