About gas-water two-phase Riemann problem
Old   April 9, 2001, 13:29
Default About gas-water two-phase Riemann problem
Ma, Dong-Jun
There is a gas-water two-phase compressible multifluid Riemann problem, governed by the stiffened gas equation of state:
p(\rho,e)=(\gamma-1)\rho e - \gamma p_\infty
For gas, \gamma=1.4, p_\infty=0; For water, \gamma=4.4, p_infty=6.E+8
And the initial conditions are For gas, \rho=1.2 Kg/m^3, p=1.E+5 Pa, velocity=0; For water,\rho=1000 Kg/m^3, p=1.E+9 Pa, velocity=0.
I have used a simple mixture-type Eulerian numerical method proposed by Saurel/Abgrall(SIAM 1998) or Shyue(JCP 1999) to simulate this problem, but the result is very poor because the pressure curve is very different from the exact solution. It is very obvious in the pressure plot for using log curve.
I think this problem is very stiff and the density ratio and pressure ratio is very high(1000/1.2 and 10000/1).
Has someone done some work in this problem and to tell me how to solve this problem?
Ma, Dong-Jun
Old   April 11, 2001, 07:03
Default Re: About gas-water two-phase Riemann problem
Dia Zeidan
It seems to me it is a numerical problem. why not to have a look to this book:
Riemann solvers and numerical methods for fluid dynamics.
By: E.F. Toro
Springer.
Old   April 23, 2001, 19:39
Buvana
Are you using an explicit or implicit scheme for time integration. I used an implicit method to solve the 2-phase problem in K. M. Shyue, JCP 1998. But in this case the density ratio is not as high as yours. but the pressure ratio is high.
Do you know how to compute temperature on the water side.
Buvana
Old   April 24, 2001, 06:11
Dia Zeidan
I'm working with isentropic two-fluid model and using exact Riemann solver, explicit scheme.
Old   April 25, 2001, 07:48
Jun Zang
I was also doing this problem last year, just in my work, for the water \gamma is taken as 7.0. I am thinking the major problem in your calculation may be the treatment of flux through air-water interface. Please check whether you keep the interface like the wave behaves itself.
Good luck!
Outflow b.c. for shallow water riemann solver phdoofus Main CFD Forum 4 April 15, 2010 16:56
ACCESS_VIOLATION problem kim FLUENT 0 November 4, 2007 02:17
Multiphase flow problem icedou FLUENT 6 July 10, 2005 03:52
Problem on boundry of two phase flow youngan CFX 0 June 30, 2003 03:32
gas flow thougth water Roued Main CFD Forum 1 October 11, 2001 10:50
