turbulent flow.......
Old   November 19, 1998, 22:50
Default turbulent flow.......
Daejin,Kang
What is the best of the turbulent model that expressed the swirl flow......????
Old   November 20, 1998, 07:08
Default Re: turbulent flow.......
Abdul Aziz Jaafar
Dear Daejin
In the rotating disc system for example, the flow away from the wall could follow a free vortex behaviour. In this case the k-e model or rstm model could reasonable capture this. If rankine vortex dominated, perhaps rstm is the best choice, as the standard k-e model, as seen the some flow problem give premature tarnsition to solid body flow. Some of the research worker improved the k-e solution by introducing several correction to the epsilon transport equation.
Hope this help
A. Aziz Jaafar
Old   November 20, 1998, 13:44
Y Wang
Dear Abdul Aziz Jaafar,
Could you please tell me details of the researcher mentioned in your message? I am calculating the through flow in a cylindrical annulus with rotating inner cylinder and I have not found suitable test cases yet.
Thanks!
Yi Wang
Old   November 20, 1998, 15:21
Abdul Aziz Jaafar
Dear Wang
Could you please decribe briefly the physical situation of your problem. You could find several flow and heat transfer problem in rotating disk system such as given in monograph below :
1. Owen and Rogers; Flow and heat transfer in rotating disc system : Vol 1: Rotor-stator system
2. As above, Vol 2: Rotating cavities
both by Research studies Press Taunton
Hope this could help
A. Aziz Jaafar
Old   November 23, 1998, 12:11
Casey McCurry
If one were to use the "toilet" example on this situation, what would be the effects on velocity of the swirl?
spectrum: LES of a turbulent channel flow finally goes to turbulent liu OpenFOAM Running, Solving & CFD 6 November 1, 2011 02:00
Difference between recirculation zone and turbulent flow region ashtonJ Main CFD Forum 0 September 16, 2011 04:46
Patch a bubble inside turbulent flow Helmi FLUENT 0 February 4, 2011 05:54
Turbulent flow through hexagonal circular pipe yogesh@cfd Main CFD Forum 0 November 10, 2010 00:10
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
