Transformation of k and eps equations
Old   March 19, 2001, 09:24
Default Transformation of k and eps equations
Marat Hoshim
Hi all,
in some papers using the SST k-omega model there's said, that the k and eps equations were transformed into the k and omega formulation. Does someone know a detailed reference, that shows how this transformation is done step by step.
Regards, Marat
Old   March 20, 2001, 08:07
Default Re: Transformation of k and eps equations
Doug
You might try Menter's paper(s) where he first introduces the SST model. They aren't overly detailed, but they do give the basic way his model combine the k-epsilon and k-omega.
The references are:
Menter, F. R., "Improved Two-Equation k-omega Turbulence Models for Aerodynamic Flows", NASA TM-103975 .
Menter, F. R., "Two Equation Eddy Viscosity Turbulence Models for Engineering Applications", AIAA Journal, Vol. 32, No. 8, August 1994.
Old   March 20, 2001, 08:46
sylvain
I don't have any reference, but you should look to papers from Aupoix et al. if there is any.
The main idea is the following :
let phi be any function of k and eps such as :
phi = k^{alpha} * eps^{beta}
it comes :
(1/phi)d(phi)/dt = alpha * (1/k) d(k)/dt + beta * (1/eps)d(eps)/dt
since d(k)/dt and d(eps)/dt are already known, it is possible to write the equation of any kind of phi. The difficulty is then to deal with the cross terms (coming form the viscous term).
hope that helps,
Sylvain
Old   March 21, 2001, 10:15
sylvain
I forgot :
omega = eps/k
Old   March 7, 2011, 09:33
The True
Eren10 is on a distinguished road
Does someone know how to transform the k-epsilon for the SST model.
I need to know how Menter came to the closure coefficients:
\sigma_{w2} = 0.856 and \beta_2 = 0.0828
Eren10 is offline   Reply With Quote
Paraview and Postscript (eps, ps ,pdf) matthias OpenFOAM 5 February 9, 2012 12:00
calculate values for eps and k from Re or u????? sbar OpenFOAM Pre-Processing 5 August 16, 2010 05:10
PS (or EPS) format from ParaView ternik OpenFOAM 4 October 4, 2009 14:47
wall function - k and eps calculation tommy CFX 0 November 4, 2008 11:44
near-wall behaviour for k, eps patrick Main CFD Forum 0 February 17, 2006 06:46
