Turbulence Model and Accuracy of convective flux calculation |
November 14, 1998, 16:56 |
HI,
We are using pseudo-compressibiliy method for solving heat trasnfer problem. We are using SST (Menter 1994) turbulence model and the code is giving convergence and good results for mixed convection in a driven cavity. However, the code is not converging for Natural convection problem (Ra = 10^11)(The results for Laminar cases are excellent in aggreement). At present we are doubting the convective flux calculations (at present central differencing with fourth order dissipation is used). We would like to know whether we are thinking in the right direction or not. Also if someone can suggest some better way of handling the whole affair. Thanx Lokesh |
November 15, 1998, 00:24 |
Re: Turbulence Model and Accuracy of convective flux calculation
Hi, I had some experience about Pseudo-Compressibiliy method, when I worked at Japan(6 years ago). I felt that the result of P-C method is very depended on the Pseudo-Compressibiliy corfficient( usual call BATE).Please try to change the value of BATE, you may get a good result. wei zhang
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 08:18 |
Wrong calculation of nut in the kOmegaSST turbulence model | FelixL | OpenFOAM Bugs | 27 | March 27, 2012 10:02 |
Fluent 12 k-w SST turbulence model | DarrenC | FLUENT | 0 | December 13, 2009 09:33 |
v2f Turbulence Model (and others?) | Travis | FLUENT | 4 | January 7, 2009 02:18 |
turbulence model for vortex flows | Günther Hasse | Main CFD Forum | 16 | October 24, 1999 13:08 |
