Turbulent wall heat transfer rate?
Old   February 23, 2001, 13:48
Default Turbulent wall heat transfer rate?
Tom
I need to calculate turbulent wall heat transfer rate. k-w turbulence model is used. So k is close to zero near the wall. This means mut is near zero. Can anyone give me a hand solving the problem? Thanks.
Old   March 1, 2001, 06:51
Default Re: Turbulent wall heat transfer rate?
Mehrdad
The near_wall heat transfer is obtained from molecular viscosity not turbulent viscosity.
Thin Wall Heat Transfer BC for rhoSimpleFoam swahono OpenFOAM Running, Solving & CFD 12 October 4, 2013 12:49
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade Karkoura CFX 0 March 10, 2011 16:35
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
No results for solid domain Gary Holland CFX 10 March 13, 2009 04:30
Turbulent heat transfer Hugo FLUENT 2 January 11, 2007 10:34
