November 9, 1998, 08:25 |
Multigrid Method in Turbulence Modelling
As multigrid method for accelarating the convergence of solution are found to be very impressive for laminar flows but can it be used for turbulent flow calculations, espacially using turbulence models. If it can be used will it have any limitations on using the type of turbulence model.
November 11, 1998, 20:20 |
Re: Multigrid Method in Turbulence Modelling
Dear Bipin
The code that I am using currently employed a multigrid method to accelarate convergence on turbulent flow computation with the Launder Sharma k-eps model. The problem that we have is to implement the method for k and eps in the wall region where we found computationally difficult, I think most probabl;y due to large gradient of eps in that region. But you can still include k and eps in the high turbulence Reynold number region. |
Turbulence Specification Method | Srivatsan V. Rajagopalan | FLUENT | 5 | January 31, 2011 07:39 |
Multigrid Method for Euler Equation | Vidhyashankar.N | Main CFD Forum | 2 | March 23, 2008 22:14 |
modelling transition with v2f turbulence model | pablo | FLUENT | 0 | August 7, 2006 16:44 |
Multigrid method | Suresh kumar | Main CFD Forum | 1 | April 24, 2006 21:07 |
