Please guide me regarding Probability Density Function Method for simulation of turbulent flows. What advantage it has over method using statistically averaged Navier-Stokes equation.
Ciao Bipin,
PDF methods are to my knowledge mostly used for turbulent combustion modeling. Here the great advantege of PDF methods is, that the chmical source term appears in closed form in the avergaged PDF-transport equations. But there are unclosed correlations for the pressure, which need empirical modeling. The closure used for the pressure correlations is quite the same as in the Reynolds-Stress modeling equations. So the results obtained for non reacting turbulent flows are quite simular, as for Reynolds-Stress modeling. Fore more details and as a introduction you may look at: S.B. Pope, "PDF Methods for turnulent reactive flows" Prog. Energy Combustion Sci., 1985, Vol. 11, pp. 119-192 Ciao Heinz |
VOF method and Marangoni flows | fmuldoo | OpenFOAM Running, Solving & CFD | 33 | August 10, 2023 06:46 |
Lattice Boltzmann method vs Finite Element Method and Finite Volume Method | solemnpriest | Main CFD Forum | 3 | August 12, 2013 11:00 |
Reacting Flows using PDF Methods | Gede | Main CFD Forum | 6 | November 29, 2005 21:13 |
pdf method in kiva | vega | Main CFD Forum | 0 | May 16, 2005 03:45 |
