January 16, 2001, 19:14 |
Read Plot3D Binary File
Anybody know how to read in a Plot3D binary grid and solution files? Thanks. John |
January 16, 2001, 23:31 |
Re: Read Plot3D Binary File
(1). You don't need to know how to read in binary files, because it is binary not ASCII. (2). What you need is the PLOT3D file I/O format. I don't have the format with me, even though I have used it. (3). Try mesh generation code vendors, or NASA/Ames. They should be able to give you the up-to-date answer.
January 17, 2001, 04:19 |
Well Well, the plot3d file format has been used in many different codes and is one of most used file format for post-processing etc. Here are two link for some info: http://fmad-www.larc.nasa.gov/~rumse...tml#MARKER-9-5 http://fmad-www.larc.nasa.gov/~rumse...ml#HEADING81-0 Hope this helps. Regards Jens |
January 17, 2001, 04:57 |
(1). Very good. I think, that's the information one will need to read the Plot3D files. One is the grid file, and the other is the Q-file. (2). Thank you very much for the website information.
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
1.7.x Environment Variables on Linux 10.04 | rasma | OpenFOAM Installation | 9 | July 30, 2010 05:43 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 05:26 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 23:00 |
