Reinolds number in SIMPLE method
Old   January 15, 2001, 07:08
Default Reinolds number in SIMPLE method
Marat N. M.
I tried to use SIMPLE-algorithm (3D laminar flow), it works fine with Re=1 ( mu=1 ), but when I use higher Reinolds numbers, the code becomes unstable.
Is SIMPLE appropriate for high Relnolds number flows? Re=1000-100000 ( mu = 0.001-0.00001 )
Old   January 15, 2001, 09:44
Default Re: Reinolds number in SIMPLE method
Sebastien Perron
1) Do you have introduce any artificial viscosity (upwind scheme) ? It is mandatory for higher Reynolds nnumber flow.
2) Is your relaxation parameter for the p' equation correctly set-up (around 0.5)?
3) Do you use an implicit or explicit scheme?
Old   January 15, 2001, 10:42
Marat N. M.
1) Do you have introduce any artificial viscosity (upwind scheme) ? It is mandatory for higher Reynolds nnumber flow. I use QUICK scheme (2nd order of accuracy) and I have not introduced artificial viscosity. If I do so, will my solution be correct and suitable? (Air viscosity is about 10e-5.) And will I obtain a backward flow behind my body (it is a cube) with artificial viscosity? As I realize, artificial viscosity means decreasing Reinolds number. Is that right?
2) Is your relaxation parameter for the p' equation correctly set-up (around 0.5)? The relaxation parameter helps a little (up to Re=10), but with Re=100 my code is still unstable. I also use inertial relaxation, but it does not help.
3) Do you use an implicit or explicit scheme? I consider a steady-state flow.
Old   January 15, 2001, 11:49
Sebastien Perron
1) Artificial dissipation is implicity introduced by using any upwinding (such as the QUICK scheme). There was a discussion on artificial dissipation some times ago on this site. For your Reynolds numbers I think the QUICK scheme should be ok (I never used this scheme. This advice is based on some readings I have done. Some people on this board could give better advices on this subject.) Or it can be explicitly introduced (I personnaly think it not a good idea).
2) Is "inertial relaxation" a false time step? (i.e using a time step even with permanent flow).
3) I had similar problems with permanent flow and high Rayleigh numbers. I had to introduce a false time step in order to get a converged solution.
4) Is it your own code? Did you validate your code on some well known problems (flow between two infinit planes, lid-driven flow, backward facing step,etc.. ) There could be a bug in your code.
Good luck.
Old   January 15, 2001, 14:57
John C. Chien
(1). What kind of 3-D problem you are trying to solve? You will have to describe it more clearly first. (2). For Reynolds number=1, how was the Reynolds number defined? and How many grid points or cells were used in the computational domain? Is it 1x1x1, or 10x10x10, or 100X100X100? (3). Assuming that your code is all right, then you can change the mesh size first to see how it affect the solution. (4). If your Reynolds number=1 case is all right, then your Reynolds number=100000 case will probably need 100000 times the mesh size to get a solution. The fact is, Reynolds number changes the solution behavior, and in general it makes the boundary layer thinner. So, in order to capture the correct solution, you will need more mesh point in the right place. (5). This is only one area which you can do some experiment easily.
Old   January 17, 2001, 12:38
guo
"You will need more mesh points in the right place" means that mesh needs be refined near the wall, is my understanding right? Can we just use wall functions to avoid the cost of refinement?
Thank you!
Old   January 17, 2001, 14:06
John C. Chien
(1). If the flow is nice and clean, yes, normally you can use wall function to avoid expensive calculation near the wall. (2). If you have separated flow situation, no, the wall function is not designed for such condition.
Old   February 10, 2001, 06:20
Default Wall function for flow separation region
rupa dutta
Dr. John C Chien
For a submerged jet of a newtonian incompressible fluid having low Prandtl (~0.1), impinging on a wall, how should one model the flow near the wall for flow and energy solution. Pls. advice with ref. of books/journals.
Old   February 10, 2001, 14:39
Default Re: Wall function for flow separation region
John C. Chien
(1). I don't know.
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 13:55
Lid-Driven cavity flow with SIMPLE method luckyxu Main CFD Forum 6 November 9, 2011 08:17
Ask help wiht a SIMPLE Method on compressible flow. universez Main CFD Forum 0 February 8, 2010 11:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
SIMPLE Algorithm & Conjugate Gradient Method Abhijit Tilak Main CFD Forum 7 March 20, 2001 01:01
