PER & MIR application
Old   January 14, 2001, 05:56
Default PER & MIR application
dimitris
Hi everyone I want to run a project in which i am using both periodicity and mirror boundary conditions.Is this going to cause the solver some problems or is there a boundary condition which is more stronger than the other and is there a way of implementing this difference in the solution or the solving? For example in a code where i define the type of periodicity for mirror bc( i.e. axis and origin)in edge and in the same time i want to apply translation bc periodical conditions in some other edge how can i be sure that both of them are implemented inside the solver code?
Thanks to anybody in advance
Old   January 14, 2001, 06:10
Default Re: PER & MIR application
John C. Chien
(1). If such condition exists in real world, then the code should be able to handle it. (2). But it does not mean that the specific code you are going to use, knows how to do it right. (3). You will have to fool around with it and check out the results yourself.
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
Others library application for OpenFoam 1.5 in Windows lcnmy OpenFOAM Installation 2 July 21, 2010 21:54
Installation of OpenFOAM15dev antonio_ing OpenFOAM Installation 34 December 18, 2009 11:06
What is the optimal (economically and user friendly) CFD software for my application? Rame Main CFD Forum 0 August 10, 2009 06:30
In-cylinder application Yogesh FLUENT 1 February 6, 2005 01:37
