cylinder streamfunction
Old   December 30, 2000, 09:20
Default cylinder streamfunction
Steven
Hi all.. I'm doing this channel flow with square cylinder in the center of channel, and the streamfunction of the bottom wall is zero, the top is 11. So logically speaking, my centered cylinder should have a stream function of 5.5, with fluctuating values at unsteady situation also about 5.5. But no matter how I try with my programme (I'm using finite difference method), I always get a value of some value higher,like 5.7 to 5.8, for my cylinder. Can anyone advise me on what might actually be wrong? I'm using the line integral of the Navier Stokes eqn for cylinder streamfunction determination. Thanks!
Old   December 30, 2000, 13:04
Default Re: cylinder streamfunction
John C. Chien
(1). When you do line integration, you will have errors from the velocity components and the integration algorithm used. (2). So, you will have to refine you mesh to get more accurate velocity distributions. (3). The other way to do is to solve the stream function equation for the 2-D problem, using the existing velocity field or vorticity field.
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 07:24
[blockMesh] Specifying boundary faces failes in blockMesh blaise OpenFOAM Meshing & Mesh Conversion 0 May 10, 2010 04:56
rotating cylinder using sliding mesh Tim Daly FLUENT 1 November 10, 2008 00:02
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 19:40
