December 23, 2000, 08:12 |
turbulent mixing layers
hi Mr need the boundary conditons for the mixing layers ant the intiales conditions. thanks a lot.
December 23, 2000, 12:02 |
Re: turbulent mixing layers
For gods sake, dont ask such a vague question. Please be specific, specially with turbulence!!
GS |
December 23, 2000, 12:40 |
(1). Yes. It is useless to use short paragraphs, if one can not get the message through. It is better to state the problem three times in three different angles. (2). Before the mixing, there must be a plate separating the two stream, therefore, you must take into account the existence of the dividing wall. (3). When the two streams meet at the trailing edge of the dividing plate, the flow field can be rather complex due to the geometry of the plate at the trailing edge. This is important, because it will impact on the solution. (4). Now ahead of the trailing edge, you have two separate streams or flow over a plate (wall), so, each stream will have a wall condition. (5). An at the place where the initial condition is known, you can set the initial condition there for each stream. And this will be the initial condition for your problem. You can specify the initial (inlet) condition of each stream as a uniform condiiton, or non-uniform condition (specify the profile). (6). As for the downstream condition, a simple parallel flow condition is adequate. (7) In other words, you will have a large box with a dividing plate in the middle, extending from the inlet location into the computational domain for a certain distance. That dividing plate will have an upper and lower wall, including the trailing edge geometry. The upper and the low outer boundary can be set to the corresponding inlet conditions. ( you can run a few cases with different domain sizes to check the effect of the outer boundary conditions) (8). This is a fairly standard problem, but you must start the computation before the two streams meet.
December 25, 2000, 22:58 |
hi: I had 2D & 3D mixing layer codes(subsonic & supersonic,Navier-Stokes eqs)but i solved plane mixing layer
Turbulent eddy diffusivity for mixing?? | Ray | Main CFD Forum | 3 | November 5, 2020 11:57 |
Turbulent Mixing Layers | Kieran Hood | Main CFD Forum | 2 | April 27, 2007 07:06 |
B.C. for turbulent mixing layers | Jason | Main CFD Forum | 2 | May 12, 2000 13:34 |
Grid for turbulent mixing layers | Jason | Main CFD Forum | 1 | March 11, 2000 21:56 |
turbulent mixing of two fluids | ulrich bieder | Main CFD Forum | 2 | October 9, 1999 16:15 |
