Stirling engine
Old   November 3, 1998, 10:20
Default Stirling engine
Rab
I am working on Design of a Stirling engine. Thisis an external combustion engine capable of converting heat energy to mechanical work. The working fluid in the engine is oscillatory and hence is in an unsteady state all the the time. Could anyone advise me on the best CFD package that can be used to solve unsteady state fluid flow (here the fluid is air or nitrogen).
kind regards.
Old   November 4, 1998, 12:16
Default Re: Stirling engine
Heinz Wilkening
I am not sure, if you can or should use a CFD-Code for your study. The reason is, as you know, a Stirling engine has a lot of different components, which define the overall performance very much.
You have to be aware of eg.:
- heat transfer in different forms such as the storage and release in the regenerator.
- complex moving geometry, made by the up and down movement of the pistons. I was told how much trouble people already have to model the piston movement in a normal internal combustion engine.
- different kinds or turbulent effects.
- and so on.
I know that people had already a good succes to model internal combustion engines just by coupling simple models for every efect in a computer code. Then you maybe use CFD to study and optimize just one component of the Stirling engine.
Never the less, when I sudied combustion engine I found Stirling engine very nice, and it would be nice if they were be used more widly.
Ciao Heinz
Old   August 16, 2010, 21:32
Zdeth
zdeth is on a distinguished road
Rab,
Were you ever successful in modeling a Stirling engine with a commercial CFD package? I"m trying to model a Pulse tube refrigerator which has many similar components and having trouble finding an appropriate way to capture the heat exchangers..
Thanks,
zdeth is offline   Reply With Quote
Modeling Stirling Engine kilovolts OpenFOAM Running, Solving & CFD 2 February 3, 2021 00:50
Stirling Engine Simulation in OpenFoam kilovolts OpenFOAM Running, Solving & CFD 3 August 21, 2020 15:57
CFD of combustion process of Homogeneous Charge Compression Engine (HCCI) kelvinlim Main CFD Forum 2 January 26, 2012 23:19
meshing of two-stroke engine in gambit ravi FLUENT 2 January 18, 2012 02:14
Stirling engine simulation advice needed Geoffrey Main CFD Forum 2 December 18, 2001 03:26
