December 17, 2000, 13:01 |
k-e OR k-w for near wall ??
hi .. can anybody suggest a suitable turbulence model to predict nearwall turbulence in a compressible flow field(without wall function approach)...
I have tried Chien's, L-S, Nagano-Tagawa, and Biswas-Fukuyama low Re k-e based models. But i have read that k-w(wilcox) model is suitable for nearwall turbulence. If anybody used both k-e & k-w ..plz advice which is better... Thanks Kuttichathan |
December 17, 2000, 13:38 |
Re: k-e OR k-w for near wall ??
(1). You may want to read the 540-page book by David Wilcox, "Turbulence Modeling for CFD", which is available at his website. (2). It is well-known that the two-equation k-epsilon model has some problems with the epsilon-equation. But it has been widely used and modified for specific applications.
December 18, 2000, 10:23 |
are you here to create trouble, kuttichathan
chidu... |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
