Block interface boundary conditions for multiblock
Old   December 14, 2000, 09:06
Default Block interface boundary conditions for multiblock
Hyun, Ko
Hi! everyone.
I am in developing a 2D FDM flow solver with multi-block grid capability. serially-linked or parallelly-link grids are solved with no difficulties.
But for grids with singularity, like backward-facing step cornder, I have a problem to appose boundary condtition at corner points.
I wrote a code that one boundary condition imposed at one boundary. And used ghost cell to interchage block-to-block information.
So, if backward-facing step problem is considered, I use 3-blocks grid. hence, there is one singularity corner point..... see the fllowing fig.
1 | 2
| ------ (1)-------------------
| 3
i meshed the problem like above fig. for block1,3, no-slip bc imposed at point (1). but, I don't know what bc is implemented at point (1) for block 2 computation.
please, give me a change to see the world of CFD..... thanks in advance.
Old   December 14, 2000, 11:08
Default Re: Block interface boundary conditions for multib
Ghanshyam Singh
Dear Hyun,
If I understand your prob. correctly, pl. do the following. First look at the figure:
~~~~~[1]~~~~~[2~~~~~Z~~~~~2]~~~~~[3]~~~~~
Take the blocks in this manner and I hope "ghosts" will not trouble you!! I mean, make the corners or step, represented by "Z", internal part of the block [2]. Which means, corners you will be handling in the same manner as we do in a single block grid. Kindly correct me if I am wrong. It was difficult to draw a good figure. I could not understand yours figure also!!!
GS
CFX does not continue Shafiul CFX 10 February 17, 2011 08:57
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 03:58
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 08:25
Fluent accuracy and boundary conditions Paolo Lampitella FLUENT 0 June 12, 2008 07:25
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 20:23
