December 18, 2000, 05:20 |
Re: Turbulent length-scale
#21 |
I believe that it could be a physical meaning for the Taylor microscale.
If you take a look to my previous mail in this thread, you will see that, in the case of decaying turbulence, what I call K_tra is on the same ratio with the Kolmogorov wave-length (K_eta) than the inverse of the Taylor Microscale. So the inverse of this wave-length and the Taylor microscale could be see as the same thing. This wave length corresponds to the point where the transfert term is equal to zero. Since the integral of the transfert term with respect to the wave length is equal to zero and due to the shape of this transfert term, this point has a physical meaning : the energy flux of the Kolmogorov cascade goes from the scales greater than the Taylor microscale to the scales smaller than the Taylor microscale. Does anybody could confirm this feeling ? |
December 18, 2000, 07:20 |
#22 |
December 19, 2000, 07:24 |
#23 |
Some researchers think of the Taylor microscale as the scale at which maximum dissipation occurs. The rate of viscous dissipation increases with wavenumber through the inertial subrange before it eventually decreases as the wavenumber gets large enough. At very high Re, the Taylor microscale is approximately equal to the Kolmogorov scale.
January 6, 2011, 22:28 |
#24 | |
pban92
Rep Power: 16 |
I hope all you guys, who participated in this thread a decade back, are doing well... Regards! Last edited by pban92; January 6, 2011 at 23:43. |
Turbulent Length Scale and Intensity for Airfoil | shamim | STAR-CCM+ | 2 | July 13, 2017 00:11 |
Integral Length Scale vs Turbulent Length Scale | Scott Nordsen | FLUENT | 2 | January 20, 2014 02:17 |
k-epsilon: Defining turbulent intensity and length scale? | klausb | OpenFOAM | 0 | January 23, 2011 08:28 |
how to calculate Turbulent Length Scale | nuimlabib | Main CFD Forum | 2 | August 18, 2009 05:22 |
Turbulent Characteristic Length/Turbulent Length Scale | fluentnoob | FLUENT | 2 | July 3, 2009 09:40 |
