Dissipation of temperature variance
Old   December 11, 2000, 10:32
Default Dissipation of temperature variance
Fabian
Hi all,
does somebody know a reference how to model the dissipation of the temperature variance epsilon_theta=thermal_diffusivity*(T'_i/x_i)^2? Where T' is the fluctuating temperature in the reynolds averaged transport eqns. I am not looking for a transport eqn. for epsilon_theta, rather an easy relationship between the temperature and the velocity field.
Cheers
Fabian
Old   December 11, 2000, 11:25
Default Re: Dissipation of temperature variance
Michael Malin
The simplest model may be Spalding's (Chem. Eng. Sci, 26, 95-107, 1971), i.e.
eps_t = (t'2/k)/R
where k is the turbulent kinetic energy, and R is the time-scale ratio, which is assumed to be constant and typically around 0.5.
Old   December 11, 2000, 12:19
Chidu
I have a few references on this:
1) A two-equation model for heat transport in wall turbulent shear flows, Y. Nagano, C. Kim, Journal of Heat Transfer, vol. 110, p. 583, 1988
2) Near-wall variable Prandtl number turbulence model for compressible flows, Sommer T. P., So R. M. C., Zhang H. S., AIAA Journal, vol. 31, No. 1, 1993.
regards, chidu...
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 07:36
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Transport Equation for temperature variance ameya OpenFOAM Running, Solving & CFD 0 December 5, 2008 02:16
temperature rise due to viscous dissipation Marek Main CFD Forum 6 December 30, 2004 17:24
temperature too high in eddy dissipation Peter Lemtis FLUENT 3 November 24, 2002 01:45
