Seeking research materials on stability analysis |
December 11, 2000, 04:16 |
Dear Sir
I started my PhD and I am looking for some research materials related to "Stability Analysis of Non-linear Finite Difference Equations" e.g., Non-linear Berger equation etc. Your co-operation is highly appreciated. Thank you Moslemuddin |
December 11, 2000, 20:53 |
Re: Seeking research materials on stability analys
Dear sir I am a PhD student in Aerospace Engineering.I am interested to find new technique for stability analysis of nonlinear Berger Equation etc. in CFD(finite difference method).I need some research material so that I can start stability analysis above mentioned equations. Thank you sincerely Yours' Md. Moslemuddin PhD student Dept. of Aerospace Engineering 43400, UPM Malaysia
December 11, 2000, 22:10 |
(1). There is a book by Richtmyer, R.D. and Morton, K.W.(1967),"Difference Methods for Initial-Value Problems", Interscience Publishers, Wiley, New York. 2nd ed., which deals with stability issue mathematically. (2). In Chapter 4 of the book "Computational Fluid Mechanics and Heat Transfer" by Anderson, Tannehill, and Pletcher (1984), Hemisphere Publishing, it also covers the stability issue for various schemes.
the research method of riprap stability around bridge piers | superhugo | FLOW-3D | 1 | November 5, 2010 09:51 |
Finite difference stability analysis | Frank | Main CFD Forum | 2 | August 31, 2006 14:30 |
Stability Analysis | skg | Main CFD Forum | 3 | June 15, 2006 08:41 |
numerical stability analysis | Wen Long | Main CFD Forum | 1 | May 22, 2002 00:14 |
Stability analysis on a non-uniform grid | PRAVEEN CHANDRASHEKAR | Main CFD Forum | 7 | July 2, 1999 01:46 |
