open channel flow
Old   November 29, 2000, 19:08
Default open channel flow
Frank
I'm working with cfd for 5 years about compressor-flow. Now I was asked if it is possible to calculate the water-flow in an open channel with a propeller in it. And as a special feature the channel is a closed system: the water comes back to the propeller.
1.) Do you know of literature about such a configuration ?
2.) Do I need VOF for the surface ?
3.) Which turbulence-model ?
4.) Do you have other hints to that configuration. I never had such a case and I do not know how to simulate this.
Thanks a lot for your help
Frank
Old   December 3, 2000, 05:47
Default Re: open channel flow
John C. Chien
(1). Why don't you do the journal search first, to see if someone has done something like that. (2). A propellar must have more than two blades on it. And the flow over the propellar is definitely 3-D, especially, with the free surface on the top of it. And it is also a transient, moving boundary problem. (3). I would say it is a good PhD thesis, but I am not sure whether there is a market for it. (4). It is easier just to put a propeller in the closed loop open channel duct, and forget about the CFD simulation.
Old   December 14, 2000, 13:15
Ghanshyam Singh
I am agree with John, there are situations where doing experiment is faster and cheaper then CFD. There is limit for any thing to crazy for.
GS
Old   December 15, 2000, 04:32
Jon Lewin
Are you men or mice?........
open channel flow with open foam windyday OpenFOAM 4 September 26, 2011 18:04
Open channel flow motaba Main CFD Forum 4 March 26, 2011 04:22
Open Channel Flow OffshoreStructuralEnginer CFX 13 August 3, 2010 22:31
pressure outlet (open channel flow) Willem Brantegem Main CFD Forum 0 April 3, 2007 10:39
Open Channel flow Boundary khalid FLUENT 1 November 4, 2006 12:53
