November 13, 2000, 05:38 |
Impingement cooling
Viewed the items on impingement modeling (PHOENICS users' forum, cfd-online). Will someone initiate discussion on: (1)flow separation leading to stagnancy zone - Falkner's proposition ? (2)loss of eddies - hence energies (3)validity of turbulence models particularly k-epsilon model in such region : for heat transfer - what special wall treatment then ? especially if it is a low Pr fluid ?
November 20, 2000, 04:57 |
Re: Impingement cooling
I think K-E model sufer in the impinging zone because the velocity droop to zero and start to build again after impinging on the plate.
[Other] Design gas turbine blades with film cooling and cooling Impingement in Ansys 12.0 | pedrin84 | ANSYS Meshing & Geometry | 7 | February 2, 2013 12:52 |
Design gas turbine blades with film cooling and cooling Impingement in Ansys 12.0 | pedrin84 | CFX | 3 | August 25, 2010 15:07 |
Design gas turbine blades with film cooling and cooling Impingement in Ansys 12.0 | pedrin84 | ANSYS Meshing & Geometry | 0 | August 25, 2010 13:19 |
convergence problem in impingement cooling | subhransu | FLUENT | 1 | June 6, 2008 01:42 |
impingement cooling | daveleo | Phoenics | 6 | November 20, 2000 01:25 |
