November 3, 2000, 15:00 |
Free DNS code ?
Does anyone know of a free DNS code which I can download. It needs to be in cylindrical coordinates because I would like to perform a DNS simulation of a coaxial jet ?
November 3, 2000, 16:19 |
Re: Free DNS code ?
what stands for DNS?
November 3, 2000, 16:53 |
Re: Free DNS code ?
(1). Would it be easier to look for DNS simulation results of coaxial jet?
November 3, 2000, 17:21 |
Re: Free DNS code ?
no, I want to run the DNS myself. And by the way, DNS stands for direct numerical simulation. I've designed a new model and I would like to tune it for a coaxial jet. I'll interpolate the DNS data onto my RANS grid. With this I can see how the turbulence model is performing with the the correct velocity field etc...
November 4, 2000, 00:07 |
Re: Free DNS code ?
Check with Turbulent research center at Stanford University. They are doing a lot of DNS Calculations.
November 4, 2000, 10:54 |
Re: Free DNS code ?
I would check the Stanford cite but their web page for Center for Turbulence Research has been down for a while. Besides, I've search their cite several times in the past and I have never seen any source code access.
November 6, 2000, 11:31 |
Re: Free DNS code ?
Hi D.R. Jones,
I guess what you are looking for is something like a link to free softwares in CFD; Why don't you try this one: http://www.math.psu.edu/dna/CFD_codes_p.html There is there a whole bunch of hydro codes in multidimensions and different geometries able to treat turbulence too. Let us know if this works. If it doesn't I can give you two more links to astrophysical CFD codes that should be suitable for DNS. I hope this helps, Patrick (D.R. Godon) |
November 6, 2000, 12:12 |
Re: Free DNS code ?
hi there,
you can download a Homogenous isotropic turbulence code (DNS and LES, fractional step, finite difference...) at the following address: http://mae.uta.edu/~lund (at the bottom of the page) It's not cylindrical, but anyway, you can modify the code to fit your needs. I hope this help. Sincerely, Frederic Felten CFD Laboratory. UT Arlington, TX, USA. http://utacfdb.uta.edu/ |
November 7, 2000, 19:44 |
Re: Free DNS code ?
#9 |
Download the flux-corrected transport modules from:
http://www.lcp.nrl.navy.mil/lcpfct there is a link there somewhere. You can do all the DNS you want with those. Allthough you will have to add all the viscous stress terms yourself. Dan. |
DNS from k-e code | Zake | Main CFD Forum | 3 | January 3, 2006 09:27 |
Looking for a free CFD code | a. | Main CFD Forum | 2 | September 22, 2004 03:13 |
Free Surface Code Validation | Maciej Matyka | Main CFD Forum | 9 | August 18, 2004 17:39 |
Where can I get the free SIMPLE source code? | Wang Dazhi | Main CFD Forum | 2 | February 28, 2002 04:59 |
What is the Better Way to Do CFD? | John C. Chien | Main CFD Forum | 54 | April 23, 2001 08:10 |
