Geometric Conservation Law (GCL)
Old   October 26, 2000, 04:38
Default Geometric Conservation Law (GCL)
James
Hi,everybody,
When simulating a rigid body moving in fluid,I want to let the mesh moving rigidly and synchronously with the body,so I only need to change the outer boundary condition at every time step.so the transformation relation between the physics plane and the computation domain is fixed and donot change with time,if so,I think I can abandon the GCL in my code,is it correct?
Thank you for your time
James
Old   October 26, 2000, 07:40
Default Re: Geometric Conservation Law (GCL)
Brian Gribben
Yes, I'm sure you're correct. Only when using a grid _deformation_ method do you need the GCL.
Mass conservation law violation in stationary case vitmalin CFX 3 September 3, 2007 14:32
Mass conservation law violation in stationary case vitmalin FLUENT 0 August 27, 2007 04:07
Test for geometric (space) conservation law(GCL) zonexo Main CFD Forum 0 April 17, 2006 12:05
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
space conservation law Dorain Siemens 1 February 22, 2005 09:11
