Psuedo Steady Simulations
Old   October 14, 2000, 01:49
Default Psuedo Steady Simulations
Greg Perkins
has anybody got experience with using commerical codes in a pseudo-steady mode?? By this I mean performing transient simulations in which you assume some equations are solved as steady (at each time-step) and some are solved as being fully transient.
I'm solving for a coal gasification reactor using Fluent. In this case I'd like to assume steady gas flow (short residence time in my reactor) but still solve for transient heat flow and material balances. In this way I would hope to use large time-steps (say 2-10 mins) since I'm interested in dynamic peformance over long time frames. If I solve this as a fully coupled problem, then the coupling between reaction and flow restricts the time-step to low values. While this is rigourous it makes the simulations impractical - I am hoping to assume steady flow at each point in time to speed things up.
Many models have used this approach in the past, but none are reported within a commercial CFD code. Has anybody tried this or got any experience?????
Regards
Greg Perkins
Time step dependence of convergence behavior of steady state simulations in CFX Chander Main CFD Forum 5 December 23, 2013 06:31
Steady solution from Transient simulations wawa FLUENT 2 November 9, 2010 18:44
CFL number in steady simulations Rol Main CFD Forum 4 August 20, 2010 10:17
transient phenomenon using steady state simulations beguxa FLUENT 2 April 15, 2010 03:22
Steady state verses Time accurate simulations Saud khashan Main CFD Forum 2 May 23, 2003 08:00
